84 Johnson 70 hp not firing on bottom cylinder
C GATOR
Hey guys I was wandering if someone might be able to give me some pointers.My bottom cylinder is not firing,there is no fire to the coil pack.The other two cylinders are fine,I dont know where to start.Thank you.
boobie
Re: 84 Johnson 70 hp not firing on bottom cylinder
Try swapping coils with a good cyl and see what happens.
C GATOR
I put a new coil pack on still no fire,there is no fire going to the coil pack
C GATOR
Maybe it has dirty contacts?
boobie
Without checking with the proper test equipment, I'd have to guess a bad power pack, timer base or wiring.
durban
Master Chief Petty Officer
you can change the wires from power pack to coils around & check it this way all it does it just changes the firing order around but put them back like you found them when finished , i do it this way then i know for sure .
