seems to do fine at low rpm and seems to open up nice a wot although not as fast as I thought it would go, however there is almost no mid throttle? mabey a inch of movement in throttle takes me from a fast idle to almost wot. I also noticed last night that I had to put the throttle about 3/4 forward to engage gear.....even heard a bit of grinding for a second (like it was trying to get into gear) Motor is fairly new to me and I havent pulled off the lower unit so what would cause this? The motor is on a 1972 cobia 19' center console (very heavy boat) at wot its best speed is 26 mph per gps....does this sound right? Thanks in advance for the help. Richie
