84 HP Evinrude Stall under load
Ed Johnson
In a barrel, when throttle linkage is rotated to rev engine, it "chokes out". Looks like only 2 adjustments. Are they low speed/idle? Input requested?
Gracias
Ed
tashasdaddy
Re: 84 HP Evinrude Stall under load
what year and model number. has this engine been sitting for a while.
Ed Johnson
1984 belcrm. been operating it every 3 weeks
Solittle
Your symptoms point to crud in the carb - not necessarily an adjustment.
Ed Johnson
Engine may have set for months before I bught it. Can be easily tunned by had by rotating flywheel, indicating compression prob and stuck rings? In BAJA - hard to find compression gauge. Your thought on freeing rings?
ezeke
I can easily turn my 1988 140 looper by hand. That doesn't tell you anything with a two-stroke engine. If you have stuck rings, usually a thorough decarb will free them if they are not rusted.
Is this motor the 50 HP One? There are no 84HP models.
Ed Johnson
yes - 50 HP, 1984.
what compression range would you expect?
Ed Johnson
Re: 1984, 50 HP Evinrude Stall under load
corrected title
