The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
I got the tiller off. How do you get the gears off that go from outside the motor to the inside. I don't see any set screws or pins?????? Help. thanks Mettyfish
Re: 84 15 hp Evinrude How to remove the tillers gears.
The one in the handle is held in by a screw that goes through handle.(Rubber grip may have slipped feel around for a hole and reposition grip as required).
The motor side has a retaining ring holding it on the back side of gear...its easy to remove and a bit of a game to put back on.
Hope this helps and good luck.
Wayne
