daydreamer1252
- Aug 7, 2007
- 212
Ready to mount trim/tilt pump assembly (tall vertical style) after cleaning and repainting, was a basket case when I got it so not aware of how it was originally mounted.....
two areas with questions.........
There are 6 (2 sets of 3) 1/4 inch holes for mounting....does this little pump NEED 6-1/4" lags to keep it stable? I was thinking 4-12x1" stainless pan head type screws.....is this sufficient?
The pump had 4 to 5 feet of power cabling, (Pos and Neg) wrapped around the motor of the pump. I can see no need for more than 2 feet for connection as it is right next to the battery......Is there a reason not to shorten the wires on this pump? Will it affect operations negatively?
It looks like a simple solution to reduce the amount of "wiring clutter"......I only wish I could easily cut off the extra 4 feet from the main harness instead of trying to find a neat way to deal with the excess......
Thanks, all comments and ideas are appreciated......
