83 Sylvan 18' rewire
GlenF
I acquired a Sylvan 18' and hull wiring is a mess. So I'm looking for a little advice to a resource where I can learn to wire it correctly and safely. Theres currently no junction box or fuses of any type, even appears to be some speaker wire to a harness on the tilt/trim pump. I'll be taking the family fishing this summer and I want it safe. So any advice is greatly appreciated! I am an auto mechanic and probably could set it up safely enough but in my experience a wise man seeks council and this isn't a car. Thank you for your time reading this.
GlenF
Oops posted in wrong place
roscoe
Contributed by another member, sorry, don't remember who.
Spend the $$ for marine grade wire (tinned) at genuinedealz. com
Alumarine
Are there no individual fuses in the dash panel?
GlenF
No theres not. Most accessories don't work and the ones that do are spliced into odd places. Theres positive wires just cut and hanging freely. Its pretty bad.
Ayuh,..... Thjere's really only one major difference,.....
Never, Ever use the hull for a ground path,.....
Always run both a positive, 'n ground wire to all of the accessories,.....
GlenF
Makes perfect sense!
dwco5051
Good page to read before starting before jumping into it. I try to always use the right colors for two reasons. First it will be easier for the next person to trouble shoot the new wiring, second it helps an old guy like me when I forget how I did it.
GlenF
I couldn't agree more, organization is a key to success, especially when on the water. Cant thank you enough for the link to that site! Its amazing!
