83 Sea Ray
82searay
Hello, does anyone the point gap for a 1983 Sea Ray merc 260 350 motor w/points I been having a heck of a time getting the info. Thanks
SteveRay
Re: 83 Sea Ray
you will get the info needed if you post in the mercruiser forum. he guys over there are awesome,
ALSO CHECK out clubsearay.com
full stringer
Re: 83 Sea Ray
the gap is .018 however if you install new points and the hexed shaped rubbing block set to .020 to allow for the block to break in then points will receed back down to .018 dont forget to grease the hexed rubbing block or they will close to tight good luck
