Ok where do I start. I'm having problems with a very rough idle and backfiring. I cleaned out the carbs new gaskets and needle valves. Did a spark test at 7/16 in. and that was ok. Compression readings are from top to bottom 126, 137, 135. I thought it might be something wrong with the timing because the guy who I bought it from got it all messed up trying to tune it, but at idle the only thing I can move is the spark arm and that doesn't help the problem. It'll start right away on first turn of key and I push the choke and it'll die almost instantly. Almost like it is getting to much gas. Thanks a lot for any help I could get, this is the first boat i've had and so far it has been a pain. Oh, i almost forgot, i did a decarb and ran it WOT for 5 minutes when it was able to go WOT, now it just kind of sputters along.
