I have a rochester carb with a "stove" bi-metal spring type choke. The when cold, the front choke plate does not close at all, making starting a matter of pumping 15 times and getting irrated. When it finally dawned on me that I was simply increasing the fuel quantity to offset too much air,I looked at the linkage and decided that the tang on the choke rod for should be in contact with thelainkage that controls the rear plate. That fixed the cold start and it fires up beautifully & idles nicely. BUT..now when the engine is warmed, that front plate does not open more than about 1/2 inch,resulting in very hard warm starts and a rich running engine ( boggy, reduced WOT r.p.m.s, smelly, etc ). When I clicked the tang back ( towwards ther rear) and it is basically not touching anything, the front plate is wide open and it runs great ( again, when warmed up ).<br />1. How do I adjust this evil thing?<br />2. Is it possible to convert this to an electric choke wihout replaceing the carb?<br />I hope this was not too confusing.
