Ok, the short re-cap so far: on my last lake test after rebuilding carbs I discovered that I had rotten fuel in at least one of my tanks. Up until the point I switched fuel tanks (ok fuel to rotten) the motor ran decent in neutral and once up on plane, but it still had a dead spot around 2000 rpm, the motor would die and didn't want to idle while in gear. As some of you suggested I tore down the carbs again, taking my time and removing every jet to inspect, I could not find a blockage in any of them, all 3 carbs were really clean despite the rotten fuel. Cleaned again, double checked everything and replaced gaskets again. (Note - I did remove and replace the small metal plugs in the carb body). Since then Ive also rebuilt the fuel pumps and replaced every gas line on the motor - I am going to run it on an auxiliary tank until I have time to remove the tanks and clean them up right.
I did a 'cold' compression test (with carbs removed) the results:
starboard side: 100, 101, 100
port side: 97, 99, 98
I am planning on testing compression again once I can run the engine.
I am also planning on checking the timing and also check spark before I run the engine again. I have read several stickys on checking the timing and they seem to differ just a little, was wondering if someone could walk me through it, anything to watch out for? I do not have a timing light but will buy one if theyre not too high.
Also, the only part of the fuel system I haven't touched is the primer solenoid (besides replacing the fuel lines). Is it common for these to need a rebuild? Has anyone done this lately? Any suggestions or other procedures I need to do before running? Thanks all you guys, sorry for the rambling!
