Thanks emdsap, I do believe it does have a lean sneeze at idle, despite the fact the plugs are wet everytime I check them. I just got done going thru the carbs for the 4th time in a little over a month, taking my time, and removing all of the jets to clean and inspect. There is absolutely no blockage, dried fuel, damage, or wrong sized jets in all 3 carbs. Went thru them completely, replaced needles & seats, new floats set to specs, all new fuel lines, removed and cleaned fuel tanks, rebuilt fuel pumps, etc. Getting pretty good and lync & sync as Ive done it half dozen times. All throttle valves completely closed at idle and moving with each other perfectly. Adjusting the idle screw raises the rpms but does not smooth it out or eliminate sneeze, pretty erratic idle. Again Im at a loss. Thank you for your assistance. Working on getting a video up like I mentioned
