83 evinrude compression
fsds123
Checked the compression on my 1983 115hp evinrude and got 130,130,130,116.<br /><br />Starts and runs great. Should I worry about the 116? I bought the motor 3 months ago and this was my first compression check. <br /><br />Thanks
Dhadley
Re: 83 evinrude compression
Its time to take a peek to see whats going on. Run a can of decarb thru it and see if you get the 116 up. You should have no more than 15 lbs difference between high and low. <br /><br />If the decarb does not bring it back pull the heads and check for a burned / blown head gasket. If the culinders all look good change the gaskets and deflectors.<br /><br />Good luck!
