chevyace68
- Jul 28, 2016
- 8
I recently purchased a 1983 Chris Craft 210SL - Mercruiser 5.7, and first time on the water, it ran great for 3-4 hours. After stopping for one of our swim breaks it started running badly. Off idle it just wouldn't accelerate over 600-700 rpms. Just chug chug chug back to marina. I was figuring it needed tune-up so I started checking things. Ended up replacing plugs, cap, rotor, wires, ignition coil, distributor pick up, fuel filter/water separator, and inline carb filter. (distributor shaft felt fine. no shaft slack) When I take it back out, twice now same result, it starts great cold, idles great, and runs smooth. WOT it is at appx 3500 rpms and around 33 mph if speedo is accurate. Both times it ran great until I stopped and let it idle. Never shut it off just let it idle for a minute. Then it will not accelerate above 600-700 rpms or so. Not sure if there is fuel pump issue, carb problem, something in fuel lines from tank to engine, or what. I am an auto technician by trade, but not necessarily familiar with carburated boats. Kind of hard to test in driveway with no load, and harder to do on the water LOL. Any suggestions? Thanks in advance
