83 Black Max Questions Help!
BLU LUNCH
I have a chance to purchase a 1983 150 Black Max for a decent price. First the motor has a ton of new parts and was always dealer serviced. The only problem is it's a 25 inch lower end and our Wellcraft V-20 uses a 20 inch the man who says the spacer could be removed and shorted with a shorter drive shaft, How much work is involed in doing this? And all so he says all the cylinders compression is between 110-115 psi I will check it before buying it. It come with all the harnesses and controls ang gauges for 800.00 he bought a new outboard from the marina I deal with . What else should I beware of I'm a OMC guy and never owned a Merc.........Thanks
MercFan
Re: 83 Black Max Questions Help!
Read post, but can't comment sorry...<br /><br />Would like to see the experts opnion on the compression though. Is 110 still within spec?
andy6374
It will cost more money to convert to 20" than the motor is worth.
Barnacle_Bill
I have no idea what it would cost to change to 20" but they are good motors. I have one and it still runs good.
Joe_McSalmon
Hi Blu Lunch, it is very easy to convert from a 20" transim to a 25".<br /><br />Get two, 4" angle steel lines aprox. 20" long, let it extend 5" past the transim and bolt the motor on. Then the motor will stick out 5" higher from the transit but will work great and will only cost you a few bucks.<br /><br />I have done this same this with great results....
bigshrimpin
Blu - email me wtbarber@yahoo.com. I will be getting a spare 20" lower unit from a v200 mercury this week and will gladly swap you for the 25" lowerunit. It's the same 1.87 gear ratio . . . <br /><br />btw - check out www.wellcraftv20.com . . . I started the site about 3 years ago . . . there are about 650 members now. The v20 is Great boat!!!!
BLU LUNCH
Thanks everybody,bigshrimpin I'm regitered at your website under the same name. I bought the motor all the cylinders were at 114-118 psi and got all the paper work from day one. new stator and triggers ,tuneup and water pump last year. Rebuilt lower unit 2 years ago, Nice SS prop, all the gauges and it looks like new I got for 700. come on spring......
