1984evinrude50hp
- May 8, 2013
- 1
60hp 2cyl. short shaft runs great without the top cover on from idle to wot. As soon as the cover is in place it will run for 2-10 seconds or so and stall out. Will not start back up with cover on. Take it off and you need to barely turn the key and it is purring away again. Motor was totally rewired over winter and has great compression both cylinders. Any ideas?
