So I bought my first boat and it had a 1983 50hp johnson. Lower unit was locked up. So I replaced it with a used one. New water pump kit. So now to get it started. I couldn't get it to idle for a while. Pulled the carbs off and rebuilt them. There was what appeared to be parts of leaves inside it. I soaked it overnight. Blew out all the passages with carb cleaner and compressed air. Right away I noticed a difference. Starts right up and runs but has a twitch to it. Tried pulling the spark plugs one at a time. If I pulled the top one it would die right away. Now the bottom was barely any change at all. Connected a spark tester to it while the top cylinder kept it running. The bottom spark didn't seem as strong as the top. So I replaced both coils, powerpack, leads, and spark plugs. Still no change in idle. Compression test came up with both cylinders dead even 120psi. I'm stumped. I was looking at the stator assembly under flywheel and I'm wondering is it supposed to move at all? It has slight up and down movement on one side and you can kinda see it while the motor is running.
