83 200hp V6 evinrude
striper
I'm thinking of purchasing a 1983 G/W with a 200 hp evinrude. Can anyone tell me about this motor it only has 900 original hrs on it.
D
DJ
Guest
Re: 83 200hp V6 evinrude
Striper,<br /><br />900 hours seems like a lot to many folks. However, I've seen "Rudes" run twice that long and more.<br /><br />How does the engine look? If it is realtively corrosion free on the outside, the inside will be similar. Does it have service records?<br /><br />With that kind of hours, you should be able to get a good deal. If the boat is worth repowering later, go for it. If you buy it right, anything the old Rude gives you is a gift.
striper
From what I've seen there is a couple rusty bolt heads and I'm awaiting the compression test. till then I'll get back.
striper
The engine don't look bad but I haven't got my comp. test back yet either. The engine compartment has oil residue but I would think that is normal. Is there some things I shoold watch out for on this power plant???
Salty Dog
Take a look at the shifter arms. Mine are rusted away to nothing.
striper
S.D.<br /> fortunatly this one has not seen salt water
