83 140 temp
tblshur
does anyone know what thermostat temp suppose to operate at j140tlcte thanks for your help
tblshur
i touched mine the otherday i could hold it there about 30 seconds wouldnt want to hold it there much longer when i go back down there i going take a hf temp gun and check it . seemed like one side little hotter then other side thank you for your help:joyous:
rothfm
Ensign
Stats are 143 degrees. By the time fully open and flowing, you may see higher, 145-150 not uncommon. Each cyl and bank will vary a bit depending where your measuring. Once opened, increasing throttle (rpm) a bit, you should see temps decrease a bit.
