SRT8
- May 5, 2010
- 28
OK I just spent over an hour reading the search results for this problem but can't find the answer to my ? so I will ask hear again . My motor is hesitating if I give it throttle fast and if I crack it WOT it will stall .This is what I have done already
-rebuild carb
-rebuild feul pump replaced filter
- all new fuel lines
-water seperator fiter replaced
-new plugs
-cleaned tank & fuel pick up
I rebuilt the carb and pump myself and it was the first time I did either but I am pretty sure I did it right .I am leaning towards a timing issue but I am no marine mechanic if I can't figure it out myself or through the forum I will take it in to have the marina that has worked on it since new .
hope you guys can help so I don't have to take it to the shop Thanks.
-rebuild carb
-new plugs
