KevinS1970
Thread starter- Joined
- Sep 24, 2018
- 7
I started my 1982 15hp Johnson motor, gave it full throttle (showing out for my son) and then I heard a backfire and the motor stopped running. I tried starting again, and the cord wouldn't turn the flywheel. I manually turned the flywheel counter clockwise several turns and then pulled the cord the flywheel is turning. But still wouldn't crank. I sprayed started fluid in spark plug hole and tried to crank. it would only backfire..The plugs are firing.. im guessing perhaps the motor jumped timing???? Do anyone have any idea what I should do before a repair man? lol.. Thanks in advance.
