Re: 82 Johnson 70HP Tach Problem
see if there's any AC voltage on the SND wire. If not, measure the voltage across the battery terminals, should be higher with the engine running. If it's
not, replace the rectifier. If it is, test the gray wire for continuity. If all the wires are good, and there's a signal on the gray one, you may just have got a faulty tach.
It is a marine tach, right?
