'82 35hp wiring harness discontinued?? Can't find it anywhere.
rebuilt
:( '82 35hp electric start- 4 wire rectifier-electric choke, tach lead. Lookin for a motor wiring harness, from the red plug to the choke solenoid.
I've looked here, at BRP, Sierra, ihop (is that a politically correct enough way to refer to the other parts site?) Not listed at any of the above. Not having any success in the hunt. Does anyone know if it's even available? Or do I need to hunt down a used one? I've eliminated the cause of what got the harness. Now I would like to put a squared away harness in it. Not just patched back with untinned copper. 'preciate the help. KR
tashasdaddy
Re: '82 35hp wiring harness discontinued?? Can't find it anywhere.
try a dealer directly. it or a replacement has to be available. you can mention them, just no direct links.
F_R
I come up with part number 391818 (verify it for yourself). Ishop lists it. They also offer a CDI aftermarket one under part number 4131818
rebuilt
Thanks guys. I've got a busy 4 yr old running around right now. I'll get on it
b4 the sun sets. Thanks again. KR
