SaintSinnerx
- Jul 31, 2012
- 10
Howdy all, been a while since i posted - recently my father and i bought a 2nd hand 60hp Johnson 2stroke - 1981
motor we have heard running, if i jump the pins on the starter solenoid will kick over without any issues and if fuel is added it will start. the fellow we bought it from had been using it for ages until one day he turned the key and it wouldn't start. but if he turns the key to ON and then jumps the solenoid it will start and run all day long. now.. i have attached two photo's that are of 1. a brown wire coming from the harness that connects the solenoid to the distribution block but was never attached.. to said bar. i cant find any visual aids to tell me where it was to be connected etc, another issue i have is it appears someone has taken a spring and stretched it from what looks to be a little solenoid that would pull the string and pull open the choke.. if someone happens to have a 1981 Johnson 60 that they would be able to take a photo for me that would be amazing.
