81 johnson 150 hp lower unit removal ?
sho-bud
I have removed all of the bolts and it is hanging up. What am I missing here?
Thanks much
jonesg
Re: 81 johnson 150 hp lower unit removal ?
Sometimes theres another bolt hiding under the trim tab,
did you disconnect the shift linkage near the carbs.
tashasdaddy
did you disconnect the shift linkage back under the bottom carb?
sho-bud
Thanks!!! That was it. I thought it was the shift rod but I couldent see where to get at it. Putting the thing in reverse put it in a position to (barely) get at it. Now my problem is the @#$% impeller is frozen on the drive shaft. Also sheared a screw off on the housing. Good times...thanks again for the help guys.
tashasdaddy
i use a dremel tool to cut the brass/bronze base off the drive shaft two cut to get it off.
