power drifter
- Jan 2, 2013
- 15
1981 well aged 25hp evinrude rope start that is on my power drifter, this thing is unpredictible but always trys & starts within a couple pulls even with temps in the teens, biggest problem is once started it revs fine in neutral but once in gear acts bogged down and wont come onto plane, coughs and sneezes a couple times then when least expected it takes off to the race and once running relatively normal at WOT it will begin to slow down approx 15% after a mile or so, replaced all fuel lines, new fuel pump, new plugs, cleaned carb ( just cleaned again and found small fabric thread in jet) ( just ordered new carb kit to do extensive cleaning) it is also slowing down at wot.... engaging the choke makes it fall on its face and pumping the primer bulb deepens the exhaust sound but neglidgeable difference in speed. i believe multiple issues are at play, lean squeeze due to partial blockage, but also suspect electrical. Tested the ignition coils with multimeter ( not sure what im looking for or at ) but one ignition coil registered resistance and the other NONE, ZIP, ZERO, removed kill switch lead and had same results. could it be power pack, how to test? the motor used to push the power drifter in the middle 30mph now middle 20's and it using fuel like its a 125hp
