niteblaster
- Jun 9, 2010
- 14
I have had my boat out twice this year and it was a little hard starting and stalled when trying to run across the lake unless I slowly increased the throttle. Both times I pulled the spark plug when I got home and it appeared to have a little water on the spark plugs. I put a set of ear muffs on and tried to start it a couple days ago and it would run about 3 seconds then die. Both spark plugs have water on them again keeping it from running. What can I check first? Would a compression test show if a gasket was leaking water inside the engine?
