Hi all. Not exactly sure of the year of this motor, although it has 89 at the end of its id #. It's light blue with a white cover.<br /><br />Anyway - where exaclty should the motor be peeing from (sorry for my lack of terminology). The only place that water seems to exiting is about one or two inches below the back of the cover - directly in the center of the light blue shaft that runs down to the prop.<br /><br />There's a hole there - water barely drips from it when idling, but when I rev it, it blows in spurts out of the hole. If this is the correct hole - should it be exibiting this type of behavior. Most modern motors I've used produced a steady stream of water out the pee whole whether idling or running full out.
