80s looper carb advise! Help
Ok guys, I replaced the powerhead on my 1986 evinrude 140 looper last summer. (TLCDC) I got the remanufactured powerhead from crowley marine which specified it as a 85-88 model. After a summer of being underwhelmed with the power the boat (19ft starcraft Eagle) has I decided to start looking more closely at the carburetors. From what I can tell the carbs that were on my 86 and now on the new powerhead are the model from 1988 because on the OMC parts catalog I found this matching number "432513".
The orifice jets installed on my carbs are as follows: No. 1- 42, 28 and 63d , No. 2- 42, 28 and 63d , No. 3- 45, 28 and 63d , No. 4- 45, 20 and 63d.
My question is on the parts catalog it says port and starboard carbs would be different sizes for a 1986, but mine has different sizes for top 2 cylinders and bottom 2. But since my carbs match up with an 1988, it says 41 idle air, 54 intermediates and 63d mains. Which jetting configuration should I be following?? Because either way the current jetting isn't correct and the boat has a hard time getting on a plane.
Faztbullet
86 is a small bore block and is jetted .002 smaller. The big bore uses 63 jets....need to find out bore size.
The powerhead is a 85-87 1.8 liter block. racerone I need to find out what are the throat measurement to determine what carbs I have. I have 2 sets, one set seems to be from a 87 120hp. The other set that is installed seems to be 88 140 carbs. I don't know the difference between mid bore and big bore carbs.
I would have to take carburetors off a 140 and off a 120 model to help.----Not going to happen without a case of cool ones .----Sorry.
I understand. Do you happen to know if hand if there were any differences in the carb bodies between the 87 1.8 liter and the 88 2.0 liter?
Faztbullet
Throttle bodies and carb bodies are different between 120 and 140..its da the venturi. You can take 2 finger and stick in the throats and feel the difference.
