1979 80 HP Mercury 4 cyl outboard<br />She runs great in the yard. Out on the water, starts right up, idles fine, but when you push the throttle down it bogs down and stalls. If you pull back on the throttle, it may not stall. IF you push the throttle down and hold in the choke until the rpms get up to speed, then release the choke, the motor runs fine until you back off on the throttle.<br />It is not the fuel filter - it's clean. The fuel line and ball are fine.<br />We are planning on ordering a carb kit, as the gaskets show wear.<br />Has anyone seen this before and do you think it is the gaskets? I read a post from someone having a similar problem - said they rebuilt the carb, and still had the same problem.<br />THANKS
