Just replaced points, condenser, rotor and cap. I only get power when key is on, not at start. Engine turns over and will start as I release the key. Any thoughts or suggestions would be appreciated.
Have you tested your ignition switch to see if both the Ignition and Start terminals get power when cranking? A quick fix would be to run a wire from the starter solenoid to the positive ignition coil terminal.
