'80 Johnson V4 115 Tilt Trim Refill
budha
I have a 80 johnson v4 115, recently a pinkish (looks like strawberry milk) fluid leaked out of the tilt ram (the ram in the middle). I flushed all of the fluid out, how do I go about refilling the fluid?? The two trim rams are fully extended and the motor sounds fine when the switch is pushed up or down but it is not moving any of the rams. Any help would be apprieciated.
usedboats4u
Re: '80 Johnson V4 115 Tilt Trim Refill
first of all you need to find out how the water got into your trim system and repair the bad seal. these units are supposed to be self bleeding, but sometimes they need a little help, fill the unit. and put it down using the manual releif screw. tighten up the screw, and raise the motor, you may have to do this several times for all the air to bleed from the system. <br /><br />good luck
