Re: 80 hp Evinrude electric start
OK, you have a loss of fire when the engine quits if I understand so far. The '68 85 hp has a battery powered CD ignition system whereby almost any part can cause a loss of fire. Key switch, coil, rotor, CD pack, or even the points. Even the wiring harness can do it. We're stressing my memory here but as best I can remember that engine has the low tension points which last a long time without burning but they are susceptible to become dirty and not conduct like they should, and they can get out of adjustment. The symptom you have described though leads me to guess that the adjustment may the culprit. I've had several engines do just what yours does, and found the points to be all but closed. As the engine warms up the expansion of the materials results in the gap closing. Check the point gap at .010".
Another possibility that should give different symptoms but still worth looking into the the wiring leading to those points. As the throttle advances the wires flex slightly. Considering the age of the wires they could be broken or the insulation could be failing.
Inspect the coil for obvious cracks and tell tale signs of spark jumping to ground. If you have an ohm meter you can also check the continuity in the primary and secondary circuits of the coil. I forget the readings but near no resistance in primary and a good bit in secondary but not an open circuit.
If the pack is bad it can certainly give you the failure you're experiencing but without the proper test equipment it's practically impossible to confirm.
Good luck. You may need it.
