I've got a 1980 9.9 Johnny that runs great and never jumps out of gear. Always shifts crisply and smoothly.<br /><br />But I did notice the other day that when in neutral, the props spins slowly. When the motor is off and in neutral I can turn the prop freely with no sounds of clicking or anything abnormal. <br /><br />The prop stops spinning in neutral if I push the shift lever (manual shift) about 1/8" toward reverse and hold it.<br /><br />It seems that my shift rod requires adjustment. Does that seem correct?<br /><br />Is there a way to adjust the length of the shift rod without dropping the lower unit? If I recall, it threads into a piece in the lower unit, but I'm hoping you can adjust it slightly where it connects to the shift lever instead.<br /><br />Thanks in advance,<br />Kev
