Picked up an old outboard on the weekend @ yard sale. Have a freind looking for cheap motor to put on small aluminum. Sears 7 hp ted williams hard to find other info. There is a tin tag under one of the motor bolts. T63 9-11 also the numbers 6494224 however hard to read. I was told it has been sitting around for a number of years. Tried starting & found gas leaking out of lower end (just above prop) I assume this is the exhaust port. The fuel system has a shut off valve & when opened in short time the fuel leaks straight through. Is this a carb problem or does it sound more serious.
