I just dropped the lower unit to replace the water pump impeller, I noticed on the end of the drive shaft approx 1/2 to 1" below the spines that there appears to be some wear/fretting. It looks like a shaft that has been turning in the inner race of a bearing. Is there a roller bearing up there that is below the female spline? If so how would you get the lower unit drive shaft back up thru the bearing on re-assembly? I do not have a service manual(yet). I would think that the roller bearing for the upper end of the drive shaft would be above the spline joint to allow for removal of the bottom end for service, but what could be causing this wear? Thanks for any input/advice. Stu
