79 Johnson Motor tilt/lock mechanism.
Sparticus777
I recently aquired a '79 pontoon with a 55 hp Johnson. (model 55el79c if that helps) The motor tilt/lock mechanism is damaged, and not likely repairable. I have had no luck searching for a replacement part, and honestly I do not know what its proper name is. It has (or had more accurately) a manual latch and lock for when not in use. I could see using this in forward only, but in reverse the motor would pull itself out of the water. Anyone know what this is called, and where to find a replacement part? Thanks in advance.
bonz_d
Welcome to the shop and forum!
Are these what you are looking for?
That is the bellcrank and stop link. On many models the stop links are no longer available new so you'd need to find them used. As you can see in the picture it was broken and bent. I was able to straighten it and weld the stop link on this one.
Sparticus777
The welded bracket looks like what is on there. I dont have the other parts. My bracket is bent and damaged too, guess I will be welding...
Sparticus777
The welded bracket looks like what is on there. I dont have the other parts. My bracket is bent and damaged too, guess I will be welding... At least my stop ling is in place. Where would you fins these used?
bonz_d
What do you mean that you don't have the other parts? The bellcrank or release knob should be on the side by the fuel line connection. That is what locks or releases the engine so that it will tilt up or lock it in the down position. The large headed bolt is what the stop link bracket slides on.
Sparticus777
Opps, sorry for the previous double post. I am missing the pin that it latches on. It looks to me like someone backed the boat up, and hit something at speed.
bonz_d
Try and post up some pictures. Mostly of the transom clamp is and the tilt lock bracket.
