79 Johnson 85 fouling "1" plug....
Target Chief
I have a 79 model Johnson Seahorse that is fouling one plug...and I mean a juicy foul; fuel running out, etc.
My question is: is it the coil or something else? What should I be looking for?
This boat was my Dad's as I was growing up...and I recently "aquired" a part of my teenage years. I really want this thing running like a top.
Can someone help me out???
Chief
ezeke
Re: 79 Johnson 85 fouling "1" plug....
You need to do a compression test. Tester should be the screw- in type.
Warm the engine, take all of the plugs out, and check one hole at a time, being as consistent as you can in the method. Record the results for later and to post here. You only need to crank a couple of seconds for each hole.
Target Chief
Aye. I'll do the compression check this week and post back. Thanks for your help.
Faztbullet
Which cylinder is fouling? If it is on 2 or 4 could be a fuel pump diaphram leaking.
