I have just got through with a cylinder repair honed out , new piston / rings / bearing,s , this is #3 cylinder after I put back together and started it up after warm up I did a compression check and the 3 old cylinders are still 125psi and new cylinder is 110 psi kinda strange for it to be lower being new and all ( but maybe rings have not seeted as of yet with only about 30 min on engine ) but I am having an issue with the new cylinder not pulling its load has good spark and compression but when I pull plug wire no change in rpm pull one above it and engine dies so tried the other 2 cylinders and each one rpm changed but engine would not die , so this tells me that the one cylinder above the one repaired is pulling all the load for that side since engine died when I pulled plug wire on cylinder #1 above #3 which was one I repaired , so my question is since that cylinder has compression and spark could it be getting to much fuel are not enough ( I rebuilt both carbs 2 weeks before engine went down ) what is best way to check and make sure that cylinder is getting fuel ? are am i thinking way off base here and it be something else.. oh and new coils and plugs ( tried both gap .030 and .040 ) 40 seems to idle better
