79 evinrude issues
reellife1
Yesterday I was on the lake pulling the kids on a surfboard for about an hour. Went back to the beach and when I was idling back the motor acted like it wanted to die. Turned the motor off and it didn't want to start again. Put the lever and start and choked it and it started fine. Lowered lever and it died. Finally had to lower lever fast and shift into gear before it died and started to head towards the dock. Went to get on plane and the engine only revs to 3k rpm at full throttle. Brought the boat home and put the muffs on it and it still does the same thing except it revs up to 7k rpm in gear. Went back to the lake and it did the same thing as earlier when its under a load. Anyone have any ideas???
southkogs
Welcome aboard:
Moved ya' over with the Evinrude stuff to see if we can get something going. '79 Evinrude of what HP?
I would start with simple stuff ... check the throttle control, look at the carburetors and do compression check on your cylinders. See if any of those things lead you anywhere.
Honorary Supreme Mariner
On the trailer and " in gear " is still nuetral.-----Reason is that that prop has no resistance / load in air !
Tim Frank
Revving to 7K with no load may soon equal no motor.
Check compression and do a drop test
emdsapmgr
Your engine will seem to run just fine, when idling on the trailer. The engine has no mechanical resisitance. It's possible that you have an ignition problem, and the engine may not be firing on all 4 cyls. You will never be able to tell that it's down on a cyl when running on the trailer. Makes a bid difference when the boat is trying to push itself through water-in gear. You will want to check each plugwire for spark. You can check with a timing light, or do a cylinder-drop test. Either will give you an idea if it's firing on all 4.
reellife1
So I figured out that I had a power pack that went bad. As ion as I got it I replaced it and it ran good on the muffs so I took it to the lake. Ran perfect as soon as it hit the water. Ran it to the end of the lake and brought it off plane. Came back on plane and ran it back down to the ramp. As soon as I came off plane and started idling it died. Tried to start it again and it didn't want to start. So I pulled the lever up to the start position and had to choke it till it started. Immediately pulled down the lever to warm up and it tried to idle but seemed to "cough" every few seconds till it coughs itself out. Thought it might be fuel delivery so I replaced the fuel line and bulb, no change. Rebuilt the fuel pump, no change. Pulled plugs and they seem wet. Don't know where to go from here???
Tim Frank
Since you haven't responded to any of the suggestions that have been offered to this point, you may find that you don't get many more.
You could just keep throwing parts at it and hope you get lucky, but that is an expensive sport....as you are finding out.
There is NO substitute for methodical troubleshooting' and you will quickly zero in on the root cause of the problem if you do that.
We still don't know whether you have compression, spark, and/or clean carbs.
My first suggestion, going forward, would be to by the OEM service manual and use that as a troubleshooting guide.
reellife1
I'm going to try to find a compression gauge and check that. Is there any way to do it without a gauge?
jakedaawg
Nope, gonna need a compression test and an open air gap spark test.
Mini auto parts stores will rent you a reliable compression gauge. Some of the Bigcheap tool stores sell junk
emdsapmgr
Crossflows run somewhat overfueled at idle. Plugs would normally be wet. Sounds like it's getting fuel. If it still won't run, likely you are missing the other ingredient: spark.
reellife1
Bad news I think... Got a compression tester and started the motor for about 5 min.
Too right 55
Bottom right 60
Top left 90
Bottom left 0
I checked several times and got the same readings. I guess my question is what is the next step.
emdsapmgr
A 79 V4 should have compression right at 125 per cylinder, when new from the factory. Did you ever think the engine was overheated?
reellife1
Not really for sure. I just bought the boat two weeks ago. I am going to pull the heads tomorrow on my day off. I will post my findings
