79 Evinrude 75hp outboard with tilt/trim.
coffeediver
While going through and replacing the deck/carpet on my 81 Kayot pontoon boat, I thought I would replace wiring. The worst is the tilt/trim wiring. The 3 wire cable comes out of the top of the tilt/trim motor but while inspecting it at the motor and taking the top plate off the motor, the brushes basically fell out. I may be able to get them back in but was wondering if just replacing the motor would be the best way to do this. The outboard is an Evinrude model 75943R. Not sure what motor for the tilt/trim would be correct. I am new with boats but not new to mechanics. Any tips would be appreciated.
tblshur
coffeediver :welcome: to a great site some local startert shops may have brushes but right here at iboats parts they have t&t motors you need to confirm fit but the part # i got is 582048,582155 seria 18-6761 and arco 6206 hope this helps:joyous:
coffeediver
Thank you for the response. I looked at the tilt motors you suggested and they do not look like what I have.
