CatfishMN
- Jun 14, 2009
- 170
So I took the boat out of the garage today to fire it up in a barrel after sitting all winter. I went to hook up the battery and for some reason I reversed the connections. I know, I know, I feel like punching myself in the face.
I believe the key was in the on position. I saw a spark, and disconnected. I think the cables were backward for maybe 5 seconds. I looked back at the motor, and there was smoke coming out from under the cowl. I let that clear, and then tried it again. Sometimes the starter spins fine, others it seems sluggish and will 'chug' really slowly. I did notice that the starter gets uncomfortably hot if the ignition wires are hooked up to the battery, but then it cools down if they are removed from the battery.
My question is - what did I damage? I did find a small inline fuse toward the back of the motor, and it had not popped. I have not had the motor running since this happened.
Any help is appreciated. Oh yeah, I bet I NEVER do that again.
Thanks!
Thanks!
