I have a 79 Chrysler 45 hp on a 15 foot thundercraft boat. after a long winter. replacing the floor, carpet, seats, trim etc.I took it to a boat repair place to have it tuned when I got the boat in the water the first time it seemed to be slowing down after a while in wot. Well, I seem to have that problem solved,It was a bad fitting on the fuel line. Now the boat runs good with two people in the boat, but you feel a real power loss with three or four people in the boat, it will not make full power. the cavitation plate is is approximatley 1" below the hull could this be my problem? The boat seemed to run better several years ago, the compression is 125 psi on both cylinders. The motor also runs better with the cover off of the motor.
