79/80 Mercruiser 140 181 cid stumbling
estebany
Steady running until I try to open up, either slowly or quickly from 3000+ RPM, then starts to stumble and quits. Starts right back up without a problem. New pump, replaced fuel lines, installed water separator, engine and carburetor rebuilt 20 hours ago. Seems to starve for fuel. Electronic ignition, spark plugs (split fires)look and are new. Thank you.
Re: 79/80 Mercruiser 140 181 cid stumbling
Sounds like you've figured out Why... "Seems to starve for fuel" <br /><br />I'd be looking at the Carb again...<br />Could be the accellerator pump, or Float levels....
akriverrat
or filters and lines from tank.
estebany
Thanks for the quick help. I neglected to mention this only happens under load. Out of gear, she goes to 4200 RPM slow or easy without a problem. I too am leaning to carburetion problems. About how much for a rebuilt?
estebany
Problem found in gas tank filter. Blew line(a little resistance)and motor runs just fine. Thanks for the help. Something to add to the check list.
