put it in the shop to get the carbs rebuilt and they found that the #3 cylinder only had 45lbs of compresion. they told me that was causing it to die under a load so i put a new piston and rings in that cylinder and new rings in the other two. i also rebuilt the carbs,put new fuel pump and all new hoses and it still dies when i put it in gear. it runs good at an idle with a slight vibration. could this be the timing?
