need4speedgal
- Jul 27, 2009
- 3
Ok I inherited a 1979 skeeter 150 hp mercury from my dad last year it was sitting in the garage for 15yrs, my husband and I got it running and it ran perfect compression was good on all cylinders and nothing was wrong with it at the time. Well this year took it out and it didnt want to go at a load you would have it at full throttle and it just wouldnt go, we took it in to the mechanic and he change the trigger, cleaned the carbs, put 4 treatments of sea foam, changed the stator and checked the switch boxes and ignition even took the whole half bottom of the engine off to check that as well, did diagnostics and all came out ok except that he thinks that one of the cylinders lower bottom half is not getting gas.. which means an overhaul he said that the oil is making it stick on that last cylinder...
. Can someone out there tell me what else we can possible do to avoid an overhaul
Oh yeah he is gonna try to change the fuel pump next...
Please HELP!!!!
