Serial # 5443137. When I shift to reverse and give it some throttle the engine kicks up. Also will leak down slowly from a raised position. Takes approx. 5-8 minutes to leak down. I have tried turning the reverse lock knob on Tilt/Trim pump both ways and still does it. Could this be leaking cylinder seals internally , or a bad pump? Or would air in the lines/cylinders cause this? I removed the T/T pump to replace brushes in the motor when I first bought boat prior to ever putting it in the water, so I don't know if it worked right before. I tried to bleed the lines, even though the mech who did my link/synch said they were self bleeding. The pump is mounted down under the transom inside boat and feeds two cylinders. <br /> Thanks for any input or advice. Stu
