79 115 Evinrude fuel blow-back
tks1954
I posted a question concerning this some time back. I have a 79 115 Evinrude that has fuel blowing back out of the carbs. The engine starts and runs fine. After running a full throttle for a few minutes, the engine is coated with a mist of fuel from the intake ports. I have rebuilt the carbs, checked compression (105# on all cylinders), removed the intake manifold and checked the reed valves. I can find no problem. Any ideas?<br /><br />Thanks for your help. :confused:
jegervais
Re: 79 115 Evinrude fuel blow-back
Fuel blow back is usually a leaf valve, leaf plate gasket or warped leaf plate issue. Have they (the leaf valves) been replaced or removed/re-installed recently? They could be over torqued. Otherwaise, did you check the leaf plate with a straight edge?<br /><br />-John
rwise
tks1954<br />I will agree with John, check the reed valve, it must be letting air/fuel back through!<br />Richard
