78 OMC 190, where's the water intake?
jeko1075
I can't seem to find the water intake, the one to hook a hose to to run engine out of water. Is anyone familiar with it's location?
jerryjerry05
Re: 78 OMC 190, where's the water intake?
Should be on the lower unit.
4 holes on both sides of the lower.#3
It needs a big bucket or muffs.
Howard Sterndrive
above the prop 1964 to 1977- water intake is horizontal - no muffs fit the electric shift units.
jerry's pic is of a 1978-1985 stringer.
your pickup is here:
you can either dunk the drive in the lake, use one of these:
or use one of these:
the last example is the best imo, because you can loosen that cap anytime you want to check your impeller flow/pressure out on the lake
boobie
Thanks Howard, you just jogged my memory.
HCMQA
Just curious.
If you use the one in the engine bay (Flusher attachment) doesn't that allow the outdrive water pump to run dry?
Howard Sterndrive
Just curious.
no, water runs both directions from the flusher
same deal for the trunnion mounted flusher. water runs back to the impeller from that type as well
