I've inherited a 1978 Mercury 1400 140hp in-line 6 engine. It seems to idle fine (I can get it up to about 2000 rpm using the idle lever). However, when I put it in gear I can certainly tell its missing on at least 2 cylinders. It boggs down and certainly does not have enough hp to pull skiers. I can only get about 1000 rpm under load in this condition.<br />I've cleaned up the carbs and checked all the fuel lines and that all looks pretty good. It starts really well on the first crank all the time.<br />I've changed the spark plugs as well with no luck.<br />I'm starting to think it may the timing, but I've never adjusted it on these motors before. It looks like the distributor cap actually moves as you throttle up/down.<br />I've heard about carburetor sync may be the issue as well. This motor has 3 of them servicing the 6 cylinders.<br />I'm not sure what other electrical components may be causing this issue. I've looked at the spark plugs wire and a few may be questionable at the distributor end. I may try and fix those next.<br /><br />Any help/hints would be appreciated.
