Re: '78 johnson 85hp rpm
i think i still have either a fuel or ignition problem. i idles good and it sounds smooth at wot. however when you hammer the throttle it will hesitate a few time then it will smooth out. i have cleaned and rebuilt the carbs, rebuilt the fuel pump, and replaced the power pack and both coils on one side. i have also disconnected the rectifier. this is the best it has run since i have had it, but i am still missing something. i could still be the carbs or the fuel pump. i play a mechanic in real life however i am not a boat nor a car mechanic. yes i have tilt and trim. the boat planes off pretty quick however i could not pull a skier at this point. sometimes it take a little longer to plane off i think due to what i am missing.
